Re: Re: Re: hydraulic fluid
Posted by Haas on May 29, 2004 at 18:43:18 from (12.65.24.27):
In Reply to: Re: Re: hydraulic fluid posted by donbunt on May 29, 2004 at 18:18:21:
The hydraulic reservoir is the block under the gas tank. There is a fill port on the side. With the rockshafts in the rear position, fill to the bottom of the fill hole. Be careful when you remove the fill plug, as the reservoir is not vented and tends to develop pressure in there. If the reservoir is over full, it will blow out when you remove the plug. The transmission level plug is on the left hand side and is likely behind the brake rod for the left side. You may have to remove the clevis pin to get to the plug. This is in the front of the transmission, left side, just behind where the torque tube attaches to the transmission. It's a 1/4 or 3/8 inch pipe plug. Transmission is full if oil comes out. The tractor also has a final drive reservoir on each side. It lubricates the pinion gear, the bull gear and the axle bearings. The reservoirs are the pans you see under the tractor where the drawbar attaches. Level should be up to the bottom of the fill hole which is a 1 or 1 1/2 inch pipe plug with a square hole for a 1/2 inch square wrench. There is no drain on the final drives. You have to remove the pans to change the fluid.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
