Re: Re: Re: Loose CLutch
Posted by Bill on May 30, 2004 at 05:49:15 from (69.37.111.109):
In Reply to: Re: Re: Loose CLutch posted by Chris Brown on May 29, 2004 at 19:30:51:
The pressure plate does not move when machine is running when pedal is engaged or disengaged. Also I can turn the pressure plate assembly by hand which also seems kinda loose? Seems strange as the clutch appears to be in good condition however when I turn by hand-which wouldn't be possible I don't think if the teeth were grabbing the drive shaft- I can here what sounds like pieces tumbling around in the assembly. Guess I will have bite the bullet and replace. It doesn't look like that bad of a job to replace-I have the manual and it appears that I don't have to wedge engine to get the shaft out so thats a plus!
Post a Followup
: Re: Re: Re: Re: Loose CLutch
