Re: Farmall H having radiator problems, plus more.
Posted by riverbend on May 30, 2004 at 07:14:21 from (208.160.34.122):
In Reply to: Farmall H having radiator problems, plus more... posted by Sean W on May 29, 2004 at 22:06:26:
You might have (or had) a head gasket leak, or worst case, a cracked head. If you look in the radiator when the tractor is running, do you see bubbles ? If so, do they smell like exhaust ? If the tractor is not blowing white smoke and your plugs didn't have a green tint on the porcelain, the leak is probably from the cylinder to the cooling system.
When you check for antifreeze in the oil, try to just let out a few tablespoons of oil. It will make it easier to see the water.
Post a Followup
: Re: Re: Farmall H having radiator problems, plus more.
