Re: Farmall M Distributor timing.....it wont start
Posted by KC SUPER M MAN on May 30, 2004 at 12:35:06 from (205.246.142.119):
In Reply to: Farmall M Distributor timing.....it wont start.... posted by Jamie Stratton on May 30, 2004 at 12:01:06:
The distributer rotates clockwise as viewed from the rear (the end the cap is on). The #1 terminal on the distributer should be marked and is the upper right. the firing order should be 1342 number 1 cylinder is to the radiator.The best way is to pull number 1 spark plug and bring the piston to top dead center and then look at your dist rotor then you can figure out the order on your dist cap Pull the spark plugs from the cylinders and put your thumb over the #1 hole (closest to the front). Get someone to crank the starter or turn the engine by hand until you feel air pushing your thumb off the hole; that's when the piston is on the compression stroke. Now look at the big pulley at the front of the engine, right below the govenor you should be able to find the timing mark close to the pointer, move the pulley until the mark lines up with the pointer (if all of the spark plugs are out you can crank the engine by turning the fan by hand). While you're turning the engine take a look at the distributor and watch which way the rotor turns. The engine is now where the spark should fire #1. Loosen the distributor and turn it until the points just open as it climbs up the cam (remember which way the rotor will turn), that's when it will fire. Now put the rotor on the distributor and see where it's pointing, the connector on the distributor cap where the rotor is pointing is the one you want to connect to #1 spark plug, then connect the other plug wires in the firing order ALSO, check your destribuutor cap to make sure it's not cracked an is functional. also replace your points and condenser, they too can be bad!!! GOOD LUCK AND WE'LL TRY TO HELP YOU OUT IF THIS DON'T HELP ANY. KC
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
