Re: Farmall M timing gears
Posted by CNKS on May 31, 2004 at 19:57:21 from (207.178.96.213):
In Reply to: Farmall M timing gears posted by Jeff on May 31, 2004 at 19:37:39:
Did you time the mag to the engine, after you put it back in? If not, you can advance or retard it while the engine is running to get it smooth. You really don't need a timing light on an M. Static timing is done with #1 at TDC. The mag is installed with the coil next to the block, and the rotor pointing to #1 on the cap. Advance (pull away from block) until it trips. (don't trip the mag with it off when you adjust it to #1 on the cap).
Post a Followup
: Re: Re: Farmall M timing gears
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
