Re: rear wheel weight bolts stuck H
Posted by Haas on June 01, 2004 at 16:41:52 from (12.65.66.237):
In Reply to: rear wheel weight bolts stuck H posted by Chris Brown on June 01, 2004 at 11:21:19:
This is for next time you do this. After you get the nuts off the bolts, Screw a nut halfway on the end of the bolt. Then screw another bolt into the nut. Now you can use a heavy sledge on the head of the bolt you screwed into the nut and the threads of the bolt won't be damaged. I've used this method several times on rusted in bolts and it never failed me.
Post a Followup
: Re: Re: rear wheel weight bolts stuck H
