IH 384 transmission
Posted by Scott on June 01, 2004 at 17:57:50 from (207.144.243.196):
Recently the transmission was stuck in reverse.
With the shift lever in neutral the tractor was in reverse. When the shift lever was in 2nd 3rd or 4th it sould stall the engine when letting the clutch out. The shifter would not go into 1st or reverse. I had to remove the hydralics just to remove the shifter and associated transmission cover to fix the problem. Now the same thing has happened again. What is the problem and how do I fix it. thanks
Post a Followup
: Re: IH 384 transmission
