Re: Fan assembly on 350 utility
Posted by Bob M on June 02, 2004 at 06:23:07 from (165.170.128.66):
In Reply to: Fan assembly on 350 utility posted by Joe in CT on June 02, 2004 at 04:54:19:
Joe - The springs etc. you see in front of the fan is the water pump “driver”. It is the connection between the fan hub and the water pump shaft (which sticks out thru the center of the fan hub). The stationary nut centered between springs is the water pump shaft packing adjustment nut.
Despite it's appearance the fan does NOT move forward and back on the pump driver springs!
Post a Followup
: Re: Re: Fan assembly on 350 utility
