Re: Electrall
Posted by Wardner on April 02, 2009 at 06:56:40 from (4.154.246.3):
In Reply to: Re: Electrall posted by D Slater on April 02, 2009 at 04:31:24:
D Slater,
Thanks for the question. You are keeping me on my toes.
After checking my Electrall Operator's manual, 400/450 parts book, and 560/660 parts book, I am sure that there is only one Electrall gearbox, and secondarily, it is impossible to drive a sidemount Electrall with a 560/660 using standard gears.
The tooth count on a SMTA/400/450 IPTO driving geears is 25 teeth. The 560/660 has three different options. They are 18, 21, 22 teeth.
One could install the earlier 25 tooth driving gear and matching driven gear in the 560/660 but it would increase the IPTO speed and the hydraulic output.
The gear you see in the Electrall gearbox is an idler gear. It is driven off the top of the IPTO driving gear. There is only one of these and there is only one of the next gear which is connected to the pulley.
So, to sum up, the reason there is no Electrall listing in the 560/660 book is because it will not work. I learned something today.
