Re: Can I change a rear tire myself?
Posted by Chris Brown on June 02, 2004 at 19:22:03 from (209.206.208.54):
In Reply to: Can I change a rear tire myself? posted by Steve W (NY) on June 02, 2004 at 11:53:55:
I have had good luck using another tractor's drawbar to break the tire off the bead. But I have also used a handy man jack(wagon jack) and a couple chains to break it down,it takes a little thinkin to get it hooked up right to push it off the rim,but it'll do it! They do make expensive little tools that slip in between the tire and rim and they screw the two away from each other.
I started out fixin our tractor tires when I was 12,I can change a tractor tire faster than wal mart can do a car tire anyday.
Post a Followup
: Re: Re: Can I change a rear tire myself?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
