Re: Whats It worth CUB
Posted by RustyFarmall on April 02, 2009 at 06:59:42 from (209.152.78.140):
In Reply to: Whats It worth CUB posted by tmiller on April 02, 2009 at 06:35:30:
You should stop bidding when you have (1) bought the tractor, or (2) can't afford to go any higher.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
