Re: H farmall pops out of fifth gear
Posted by Kelly C on June 03, 2004 at 06:10:34 from (63.171.43.140):
In Reply to: H farmall pops out of fifth gear posted by larry on June 02, 2004 at 22:01:27:
third party image
5th gear is different then all the other gears in the transmision. It is a gear you do not want to grind while putting in gear. Unlike the other gears that are just a standard type gear that meshes with the one below. 5th gear actually ingages by moving over the input shaft.
Here is a photo of the 4th and 5th sliding gear.
As you can see if you grind the gears you can do the same thing as stripping out a phillips head screw. Could also be some of the things others have mentioned. or all of the above.
Hope this helps.
Post a Followup
: Re: Re: H farmall pops out of fifth gear
