Farmall M Restoration/Moderization
Posted by Mike Athanas on June 03, 2004 at 17:42:20 from (64.12.117.22):
I am rebuilding a 1948 "M" serial#175083.
Things I have done and will do to this beautiful hunk of rusty iron.
Total engine rebuild
full grind on crank
power grind on camshaft
ported head and manifold
may make the exhaust into a dual stack
prepressure lube system
live hydraulic pump on engine
electronic ignition
Wide front end ( original IH )
Power stearing unit installed
Remote grease fitting for upper bolster
Convert to 12 volt system
2 Spool hydraulic valve mounted on stearing column
modern seat with arm rests
3 point hitch on back
All new tires
New shinny RED finish
Numerious other 'LITTLE THINGS'
THOUSANDS OF MAN HOURS
Post a Followup
: Re: Farmall M Restoration/Moderization
