Re: International 766
Posted by Farmall Doctor on June 03, 2004 at 19:17:42 from (69.156.109.35):
In Reply to: International 766 posted by Wayne on June 03, 2004 at 12:04:03:
If it is grinding too much, then set up the transmission brake. Also check that you don't have too much clutch free play. If it is taking alot of force to shift, and not grinding, then the linkage needs to be lubricated- there is a grease fitting up top, and use a good penetrating oil (I like MOPAR penetrating oil!!) on the rest of the linkage.
If it feels loose, check the clevises and pins at the bottom, and also, like the others said, the roll pin in the shaft. It is a special heavy duty pin that is rolled to near solid. A regular roll pin will eventually break.
Hope this helps, Regards, FD
Post a Followup
: Re: Re: International 766
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
