Re: 350U Hydraulic Oil Temperature Problem
Posted by Randy in NE on June 04, 2004 at 04:12:41 from (216.58.237.20):
In Reply to: 350U Hydraulic Oil Temperature Problem posted by Ibby on June 04, 2004 at 03:21:18:
It will do a couple of things for you. One it will not cause the coolant temperature to get too hot unless you are totally blocking the entire radiator. Something like an automatic transmission oil cooler should work just fine. Also by adding the cooler you are increasing the volume of your system so that will help some, albeit not very much. Although the tubing/hose to the cooler will dissipate some heat.
Post a Followup
: Re: Re: 350U Hydraulic Oil Temperature Problem
