Re: Re: 350U Hydraulic Oil Temperature Problem
Posted by big fred on June 04, 2004 at 07:37:47 from (130.76.32.145):
In Reply to: Re: 350U Hydraulic Oil Temperature Problem posted by D.C. Arnold on June 04, 2004 at 06:19:32:
The 350U will be quite different, if you are talking about the little screen about the diameter of a pencil in the relief valve. Mine was plugged also on my 300U. To get at it on a 300U/350U, you need to remove the pressure regulator/safety valve, that is mounted on the right rear of the reservoir (the seat mounts on the top of the reservoir). Remove the end cap and there will be two large cavities with springs and the screen you mention is kind of between them, looks like a screw with a hole in it.
Post a Followup
: Re: Re: Re: 350U Hydraulic Oil Temperature Problem
