Farmall Tractors Discussion Board
Re: Farmall M Ignition box
Posted by Farmer Bob on October 28, 1999 at 19:36:10 from (207.227.187.238):
In Reply to: Farmall M Ignition box posted by Jim Wright on October 28, 1999 at 19:04:45:
Jim, I think you're refering to the short piece of wire that looks like it was wound around a pencil and is attached to two terminals on the switch block. This is a dimmer resistance for the headlights and not a heater. (Unless IH slipped a mod in there on me when I had my back turned), I've never known that box to have a heater in it.
The value of that dimmer resistance is suppose to be 5 ohms and as a resistor, it disipates current when you are running the lights on "Dim" I suspect you may have a wire connected wrong inside the dust proofed relay box. Your M service manual would be a good source for a correct wiring diagram. BTW, you don't have cigarette lighter mounted in that box do you? I've known some farmers to mount one in there for light'n stogies on the go! Good luck! FB
Post a Followup
: Re: Re: Farmall M Ignition box
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
