Re: H magneto weak spark
Posted by Wayne Swenson on June 05, 2004 at 06:18:38 from (66.228.234.121):
In Reply to: H magneto weak spark posted by Dave on June 05, 2004 at 05:05:00:
The impulse coupling may be stuck and need cleaning.
Rotate the engine so the mag rotor points to #1 spark terminal, then take the mag off for inspection & service.
Post a Followup
: Re: Re: H magneto weak spark
