Re: Re: Re: Re: H magneto weak spark
Posted by Bob M on June 05, 2004 at 08:26:34 from (66.67.11.95):
In Reply to: Re: Re: Re: H magneto weak spark posted by Dave on June 05, 2004 at 07:56:49:
Dave - It's entirely possible on 12 volts, cranking the motor spins the mag fast enough to deactivate the impulse. However by turning the crankshaft by hand you should get a noticable "snap" from the mag every 1/2 crank revolution.
Not a bad idea to replace the mag condenser (and also the points while you are at it). They can deteriorate with age and may become temperature sensitive. Same deal with the coil - though at $50 or so for a new one you may want to save replacing it for last!
Incidentally it's normal for the grounding post to appear grounded. The current path is thru the coil primary when the points are open. The actual resistance then is only a fraction of an ohm - hard to distinguish from a dead short to ground with most VOMs and DVMs.
Post a Followup
: Re: Re: Re: Re: Re: H magneto weak spark
