Re: Omni paint code
Posted by El Toro on June 05, 2004 at 11:13:51 from (64.12.117.22):
In Reply to: Omni paint code posted by Seth on June 02, 2004 at 11:27:45:
Hi Seth, I've never used Omni paint, but I've used Dupont, Acme and PPG. Any auto parts store
can furnish you with paint. I'd recommend using
acrylic enamel with the catalyst hardener. I've always had good luck using this. I always use a
primer that calls for a hardener and it comes in gray or red. You should get A HVLP spray gun since this will cut out a lot of over spray. They aren't that expensive now and will last for years. Good luck, Hal
Post a Followup
: Re: Re: Omni paint code
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
