Re: Where to start on Hydralics on 404?
Posted by J in Pa on June 05, 2004 at 17:13:58 from (24.154.96.166):
In Reply to: Where to start on Hydralics on 404? posted by BB on June 04, 2004 at 20:01:20:
BB after you change the filter, did you fill the canister that holds the filter with oil? this is needed to insure the pump doesnt run dry. also aids in re priming the hydraulic pump. also there should be a screen around the filter. most of the time they get cloged before the filter. clean it good or replace it.
good luck
J in Pa
Post a Followup
: Re: Re: Where to start on Hydralics on 404?
