Re: A Farmall, loss of oil pressure
Posted by steve c on June 06, 2004 at 03:52:12 from (152.163.253.103):
In Reply to: A Farmall, loss of oil pressure posted by RLS ia on June 05, 2004 at 21:45:37:
hi, it could have blown a gasketin the oil pump. just overall 45 farmall A, and it had a blown gasket. you should have got 2 thin gaskets with your gasket set. I also use adesive tack you can get from auto parts, it is yellow and will stick it together good if you let dry hope this helps Stevec
Post a Followup
: Re: Re: A Farmall, loss of oil pressure
