Farmall Tractors Discussion Board
Re: Pull-behind mower for a Farmall Model A
Posted by Phil Auten on October 29, 1999 at 04:19:16 from (206.175.72.226):
In Reply to: Pull-behind mower for a Farmall Model A posted by Dan Bauer on October 28, 1999 at 15:16:18:
Dan,
A Farmall A should be able to handle a 5' pull type rotary (brush hog style) mower or a 6' sicle bar mower. The sicle bar mowers are available in either mounted or pull type. Either way you go, I would recommend that you get an overrunning clutch for your PTO shaft. This will keep a rotary mower from pushing the tractor when you depress the clutch to stop. The clutch costs about $50-$65 depending on where you buy it, and it's the cheapest insurance you'll ever buy. It has the additional advantage of letting you stop and start the tractor without having to wait for the mower to spin down so you can reengage the PTO.
My two cents,
Phil
Post a Followup
: Re: Re: Pull-behind mower for a Farmall Model A
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
