Farmall Tractors Discussion Board
F-20 or Regular ?
Posted by sn on October 29, 1999 at 06:22:01 from (206.153.208.153):
Can anyone help identify this farmall? I suspect it is a regular that has a F-20 clutch housing. The # 107363 is stamped on top of the left frame rail just forward of the radiator. QC82855 is stamped on a flat boss on the front left side of the block. The toolbox tag is missing.I think it has a F-20 clutch housing, because it has a starter mounted on the lower left side. Did any regulars have starters? What years of F-20's had starters? The steering gear is exposed. The transmission is locked up, but appears to be a 3-speed. It also has a Heisler overdrive mounted to the front of the transmission. Neither of the numbers are located in the same places as on my 36 or 37 F-20. These numbers weren't on the list in the Sept-Oct 99 Red Power Magazine. Thanks for any help.
Post a Followup
: Re: F-20 or Regular ?
