Re: Farmall M MW Hand Clutch
Posted by Kelly C on June 08, 2004 at 20:14:17 from (63.171.43.140):
In Reply to: Farmall M MW Hand Clutch posted by Adam Burke on June 08, 2004 at 18:29:10:
M&W clutch is pretty simple actually.
There are metal plates that have gear teeth along the inside. These gear teeth are geared to the Bull pinion. Then there are fiber mat disks that have gear teeth along the outer egdes.
These are geared to the brake drum.
The metal disks are spaced between the fiber disks. When they are compresed together. You get motion. When the presure is released. The outer and inner disks move independent of each other and motion of the trator is stopped. Wile the PTO still spins.
The compresion of the disks is acomplished via a ramp and roller set. When the handle is moved this forces the ramp to ingage the rollers. Pushing them into the plate that pushes the clutch disks Causing ingagement.
Wear of the disks is what causes the clutch to slip. Once the wear is past the ability of the ramp and roller to ingage the clutch. Well you dont move.
If disks are not warn out you can adjust the ramp and roller to compensate for the wear.
Remove the cover on the front of the clutch and there is a big nut that you can tighten to take up the slack. If this does not work then the fiber disks need replacing. If you need to replace the disks. Good luck finding a set. M&W does not support them any longer. There are some companys that specialize in geared facings. But its not a easy task to get them to help you as they like big customers. But it can be done.
Good luck.
Post a Followup
: Re: Re: Farmall M MW Hand Clutch
