re: on 1466 noise in rearend
Posted by Bryce Andreasen (Magnum) on June 08, 2004 at 20:36:22 from (209.74.224.41):
in a responce to the 1466, the noises echo with the fenders for some reason. For example, i have a 5 foot rhino mower, running, going in low 4th, roughly 2000 rpm, put the clutch in, and let it roll for a few feet or 2 seconds after, it will slow down like brakes are being applied (but realy arent) and it will quickly "pop" foreward, and sound like someone is hitting the inside of the fender with a hammer just once, then nothing. Although if you have the same conditions, but when you put the clutch in, and apply the brakes fast, it will make no sound or motion. in certain conditions, the TA will not catch in the low side, like if you go 3rd hi, TA ahead, shift to hi 4th, then pull the TA back, it will not catch. I don't know if that means anything. the main thing is, can i pull once at the county fair and be okay, i am planning on putting a new TA in afterwards if possible.
Post a Followup
: Re: re: on 1466 noise in rearend
