Re: 1944 Farmall H - how do you drain hydraulics
Posted by Dave in CT on June 09, 2004 at 11:54:15 from (64.252.220.222):
In Reply to: 1944 Farmall H - how do you drain hydraulics posted by Todd Kelsey on June 09, 2004 at 10:12:57:
There's a drain plug at the bottom of the lift-all pump/resevoir - that nodule that sticks down from the belly of the tractor just in front of the light switch support. The plug is just behind where those two keyhole-shaped holes are on either side of the tractor. Unscrew the drain plug and unscrew the filler cap (on top of pipe that sticks up on the right ('passenger') side just in front of the belt pulley mechanism). This will let air in to facilitate the draining and you can check to make sure the breather holes in the filler cap are open while you're at it. The 1940's manual and purists say to use 30W _non-detergent_ oil in the hydraulic system. If you use 30W oil, make sure it is non-detergent (harder to find) as the detergent stuff will foam and the hydraulics won't work. After reading some posts here, I switched to using hy/trans oil (Wal-Mart is the least expensive source). If the system doesn't have any leaks, this oil works well and gives better wear protection in all temperature ranges. Also, if you switch implements between this and other tractors that use hy/trans oil, you don't have to worry about mixing unlike oils. If the system doesn't have any leaks, I'd work it a bit and then drain and fill it again sometime soon to flush the age and wear sludge out - waiting until a rebuild to get it completely clean. If it does have leaks, it's only about $30 from Carter and Gruenwald for all the gaskets and balls and springs to rebuild it. These are mostly my opinions on the matter but this should get you going.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
