Re: Pulling a diesel to start it
Posted by Farmall43 on June 10, 2004 at 12:36:00 from (24.56.231.77):
In Reply to: Pulling a diesel to start it posted by Dale on June 10, 2004 at 10:17:44:
Yes, it will start by pulling it. My 400 will not start on gas either. I pull start about twice a year just to move it and get every thing lubed up until i get to it. I pull it with my 450 gas in 3rd and the 400 in 3rd. About half throttle. you will notice unburt fuel seeping out of the stack and do not wear anything white when attempting this. It will run rough at first. Just let it sit there and idle for a few minutes until the smoke clears up from white. In 80 degree wheather you will need to pull it about 100 yrds. In 60 degrees it takes about 400-600yrds.
Post a Followup
: Re: Re: Pulling a diesel to start it
