Re: McCormick Deering Lime Spreader?
Posted by Hugh MacKay on June 10, 2004 at 14:16:17 from (209.226.247.126):
In Reply to: McCormick Deering Lime Spreader? posted by rex on June 10, 2004 at 13:35:17:
Rex: You say rims so I gather this lime spreader is on rubber tires. There was an early McCormick 8 foot lime spreader built from 1915 to 1948, but it is on high steel wheels with spokes. those were followed by two rubber tired models. The No. 6 and No. 7, and they both hsve disk or flange type wheels. I believe I remember seeing a high wheel rubber tire version, with tire 3 to 4 inches wide. Tell me a bit more.
Post a Followup
: Re: Re: McCormick Deering Lime Spreader?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
