Re: block drain plug on H
Posted by Bob M on April 02, 2009 at 07:56:48 from (151.190.254.108):
In Reply to: block drain plug on H posted by DTK on April 02, 2009 at 06:01:39:
I've had good luck doing this: Push increasingly larger drills thru the busted plug until you begin to see the plug threads. Then go at what's left with a chisel to collapse the thin shell of the plug that remains - it'll crumble surprisingly easily.
Once the old plug's gone run a pipe tap - I think it's 3/8" NPT - thru the treads in the block to clean 'em up. To prevent the new plug from getting stuck give the threads a good coat of teflon pipe dope or Neverseez before screwing it in!
