Re: Re: Pulling a diesel to start it
Posted by Dale on June 11, 2004 at 06:43:49 from (134.84.43.11):
In Reply to: Re: Pulling a diesel to start it posted by Haas on June 10, 2004 at 12:19:31:
Haas - How do I check the manifold butterflys to make sure they are sending air to the carb as they should? Do you take the carb apart to see if the carb float is releasing?
Thanks for all the good notes. Dale
Post a Followup
: Re: Re: Re: Pulling a diesel to start it
