Re: Carburetor float help!!
Posted by Bob M on June 11, 2004 at 07:50:48 from (165.170.128.65):
In Reply to: Carburetor float help!! posted by Andrew Kopel on June 11, 2004 at 06:14:18:
Andrew - Suggestions for a few things to try: 1 – With the carb still on the tractor remove the float bowl. Lightly lift the float with one finger (to close the needle valve) then open the fuel shutoff at the sediment bulb. If any gas appears the problem’s somewhere around the needle valve. Look for a defective needle or seat, junk caught in the needle valve, bad or missing gasket ring under the valve seat fitting, or possibly a crack in the casting where the seat screws in. 2 – Now let the float drop with the shutoff valve still open. Gas should run freely from the float needle valve. Lifting the float again should immediately stop the flow. 3 - If the above checks out, reassemble the carburetor then remove it from the tractor. Invert the carb and shake it up and down. You should hear a distinct rattling as the float moves inside. If you hear nothing the float’s binding somewhere – you’ll need to remove the bowl find it. Or with the carb inverted, apply light and gradually increasing air pressure at the fuel inlet. At low air pressure (5 psi or less) you should hear nothing. However as pressure increases at some point you should hear a hissing or farting sound from within the carb as as air pressure lifts the needle & float. (I applaud your commitment to your new daughter for your use of “G” rated language, but I cannot think of a G-rated term which more accurately describes the sound!). Anyway if you hear air escaping even at low pressure, it again indicates a float bind. Look for a bent or distorted float hinge, bent float arm, etc. Good luck and post back what you find!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
