Re: Re: 706 gears
Posted by K.B. on June 11, 2004 at 14:42:48 from (209.163.30.27):
In Reply to: Re: 706 gears posted by Aces on June 11, 2004 at 12:41:34:
Only gotta split once, I'm sure of that. It's been awhile, I can't remember if the shift collar slides right off after splitting, or if you need to remove the final drives, differential, and then remove the top shaft to the rear. I'm about 95% sure that the shift collar slides right off after splitting.
Post a Followup
: Re: Re: Re: 706 gears
