Re: F-20 missing issue for you advance problem sol
Posted by El Toro on June 12, 2004 at 09:35:25 from (64.12.117.22):
In Reply to: F-20 missing issue for you advance problem solvers posted by Pete L on June 12, 2004 at 06:33:26:
Hi Lee, After checking that intake for leaks and the compression on each cylinder and if this doesn't help check your valve adjustment. Make sure you're on the compression stroke and rotate engine until the rotor points to No1 and the timing marks are aligned. Adjust valves on No1 cylinder and then rotate engine to the next plug on the distributor which should be No3 and adjust, then No4, then No2. You may not have enough clearances on your valves. You will lose a little clearance as the engine gets to operating temperature. Good luck, Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
