Re: Farmall 100 steering
Posted by gene b on June 13, 2004 at 03:52:28 from (67.1.108.83):
In Reply to: Farmall 100 steering posted by J D Carter on June 12, 2004 at 12:35:43:
i have repaired several over the last few yrs and with new bearing and bushings and seals have been happy with the results. The one i have had fow 15yrs and still no leaks and i use 90wt.
Post a Followup
: Re: Re: Farmall 100 steering
