Re: F-20 missing issue for you advance problem sol
Posted by El Toro on June 13, 2004 at 05:46:01 from (205.188.117.22):
In Reply to: F-20 missing issue for you advance problem solvers posted by Pete L on June 12, 2004 at 06:33:26:
Hi Pete, Did you check that valve lash for correct clearances? If the engine still misses after adjusting valves pull one plug wire off at a time to see if you can determine which cylinder is missing. If that cylinder head has had numerous valve jobs, the valve seats may be to deep in the head and should've had inserts installed. Run a compression check on all cylinders with the throttle wide open, the readings should be very close to one another. Did you use new valve springs? A weak valve spring will cause a miss. I had a 57 Chevy that had a miss and I checked everything, but never could find the problem until the spring broke. After replacing the spring it cured the miss. When I did the head I used the old springs, I always used new springs after that. I know they say you can use valves when the valve thickness are 1/32" thick. I replaced exhaust valves if they're that thin. Update us if you find the problem. Hal
Home
| Forums
Today's Featured Article -
Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
