Re: Re: F-20 missing issue for you advance problem
Posted by JRM on June 13, 2004 at 07:03:34 from (64.12.117.22):
In Reply to: Re: F-20 missing issue for you advance problem sol posted by Tom Fesenmyer on June 13, 2004 at 06:00:47:
My F20 has run like you describe for as long as I can remember. As you say, it idles like a cammed up hemi and smooths out and pulls like a mule under load. I've often wondered if it should run smooth all of the time. Mine still uses the kerosene carb, but I run gas in it. Is it possible that the kerosene carb puts out too much fuel at lower rpms and loads up the engine?
Post a Followup
: Re: Re: Re: F-20 missing issue for you advance problem
