Re: Re: F-20 missing issue for you advance problem
Posted by Pete L on June 13, 2004 at 09:50:34 from (24.236.154.30):
In Reply to: Re: F-20 missing issue for you advance problem sol posted by Allan on June 12, 2004 at 06:47:00:
Hey guys - - Thanx for the feedback, and lots of it. The missing situation didn't appear to get worse or better once the head was rebuilt, so I'm kinda ruling that out for now. The missing situation seems random between the cylinders, as no one cylinder seems to be better or worse than the others when plug wires are pulled.
Being it is a random missing situation between the cylinders, I have to assume is it something to that is shared between all the cylinders. I need to zero in on the intake system thru the carb and up into the manifold. Anybody have any idea what "adequate" vacuum should be? Also, how much looseness in the throttle shaft in the carb will affect this problem?
I'm off to the garage this afternoon (Sunday) to do some more exploring. Check back on Monday for updates. Thank all for your input thus far.
Pete
Post a Followup
: Re: Re: Re: F-20 missing issue for you advance problem
