Re: Re: Farmall C Govenor problem
Posted by Ken Koch on June 13, 2004 at 11:01:39 from (67.200.32.40):
In Reply to: Re: Farmall C Govenor problem posted by gene b on June 13, 2004 at 03:57:54:
I had the same problem with our Farmall A and B. When I took them apart I found someone had used the wrong parts, parts woren out etc. I had to completely rebuild the governors. Now they work like new. Don't forget to change the pins holding the fly weights in your rebuild. If the holes in the weights are woren to much, you may have to replace the weights also. Most parts, pins, bearings, bushings, gaskets are still available from your Case IH dealer. Make sure you have a good manual before you start also. Rebuilding these governors is a fun little project and is worth the effort. When these governors are in good condition, they are a very sensitive acting governor. Good luck with your rebuild!
Post a Followup
: Re: Re: Re: Farmall C Govenor problem
