Re: Electrall
Posted by Wardner on April 02, 2009 at 08:09:13 from (4.154.240.205):
In Reply to: Re: Electrall posted by John G. Hasler on April 02, 2009 at 05:38:46:
The 115V outlet receptacle on the Electrall is limited to 15 amps. The two separate outlets for the 230V single and 208V three phase are capable of full generator output of 37.5 amps as a total load when both are used. Through the use of a separate distribution panel, one can use the full 37.5 amps in 115V if no other loads are connected. That would be 75 amps of low voltage. Manual says the Electrall is capable of "2 to 3" times 37.5 amps for a brief period. This would allow for starting large motors such as the GE Electrall farm duty baler motor.
third party image
Generator tag
third party image
Electrall motor tag
third party image
Motor and generator
