Re: Re: F-20 missing issue for you advance problem
Posted by pete L on June 14, 2004 at 05:00:45 from (198.36.89.4):
In Reply to: Re: F-20 missing issue for you advance problem sol posted by Hermit on June 12, 2004 at 19:48:36:
Hermit - - I was suspicious of the valve timing last summer. The book said that on #1 cylinder, the exhaust valve should close just before TDC, and the intake open just past TDC. My tractor proved to be running 10-15 degrees late on all valve actions. The book also said that the starting crank pin in the nose of the crank shaft should be horizontal at TDC. It is 10-15 degrees off in the same direction also. Last summer, I moved the cam shaft timing gear 3 teeth to get the valve timing in line to the book. Problem wasn't apparently better or worse. Thoughts ? ? ? Pete
Post a Followup
: Re: Re: Re: F-20 missing issue for you advance problem
