Re: H STARTER
Posted by Bob M on June 14, 2004 at 05:16:29 from (165.170.128.66):
In Reply to: H STARTER posted by OBie nh on June 14, 2004 at 01:45:05:
Problem's most likely a worn starter drive pinion. Figure about $40 if you replace the drive yourself.
Don't shim the starter away from the flywheel! All that does is hasten wear on the remaining engaged portions of the ring gear teeth. The previous owner did that to one of my tractors. In addition to having to replace the starter drive now I gotta split the tractor to replace the ring gear - back half of every gear tooth is nearly worn off.
Post a Followup
: Re: Re: H STARTER
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
