Re: Help with Removing Bearing retainers from Farm
Posted by parts man on June 14, 2004 at 15:33:13 from (142.166.242.212):
In Reply to: Help with Removing Bearing retainers from Farmall posted by Kevin on June 14, 2004 at 03:49:01:
Do you mean the seal retainers on the side on the differential housing?? Once you get the 3 bolts out, they pull straight out. They are a snug fit, so you need to bring them out straight. You should be able to catch something of them with a small pry. Try tapping a slot screw driver in under the lip.
Post a Followup
: Re: Re: Help with Removing Bearing retainers from Farm
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
