Re: 300 Utility need wiring info for rebuild
Posted by Ibby on June 15, 2004 at 03:10:26 from (64.14.92.197):
In Reply to: 300 Utility need wiring info for rebuild posted by Inyuition on June 14, 2004 at 17:11:25:
A lot depends on if you want an "original" restoration or not. If you want it just like it came from the factory, get a GOOD manual or buy a wiring harness. If you're after a functional tractor, it's easy to do it yourself. Install a 1 wire 12 volt alternator, run the wire from the alternator to the amp meter, then to the battery terminal on the starter. Run another wire from that post to the ignition switch then to the distributer. Wire in a momemtary contact switch to the start terminal on the starter and you have a MINIMALLY functional system
Post a Followup
: Re: Re: 300 Utility need wiring info for rebuild
