Re: Replacing M belly pump bearing ??'s
Posted by Haas on June 15, 2004 at 16:46:18 from (12.65.30.220):
In Reply to: Replacing M belly pump bearing ??'s posted by nick on June 15, 2004 at 14:14:22:
IH part number is 50839D for the countershaft front seal. Likely that is an old number and the seal is replaced with a newer version. Tell the IH dealer you want the transmission countershaft front seal.
Post a Followup
: Re: Re: Replacing M belly pump bearing ??'s
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
