Re: My 74 internation cub
Posted by Phlogiston on June 15, 2004 at 20:41:41 from (65.129.84.24):
In Reply to: My 74 internation cub posted by Bob on June 15, 2004 at 20:21:49:
The in-line fuel filter is fine, but it wust be a gravity fed filter. This may be your problem. Is the inside of your fuel tank clean? Any rust flakes entering the fuel bowl? Also pull the main metering jet (large brass hex head) on the side of the carb. Make sure the passages are clear. Use fishing line or compressed air. No metal as the size of the openings are critical. Also check the small filter at the carb elbow to see if that screen is plugged.
Phlogiston
Post a Followup
: Re: Re: My 74 internation cub
