Re: Farmall B Problems
Posted by Steve W (NY) on June 16, 2004 at 05:23:47 from (24.213.210.222):
In Reply to: Farmall B Problems posted by David B on June 15, 2004 at 20:51:41:
I can't help you with the belt pulley, but the fan is easy to check...loosen the fan belt and feel the fan. It should rotate nice and smooth, with no wobble. I'd bet it doesn't. Luckily it's easy to pull out. Be careful of the radiator.
Good Luck
Steve
Post a Followup
: Re: Re: Farmall B Problems
