Re: Re: Re: Re: Re: Super A cubic-inch displacemen
Posted by Stan(VA). on June 16, 2004 at 06:15:03 from (208.59.156.13):
In Reply to: Re: Re: Re: Re: Super A cubic-inch displacement? posted by Hugh MacKay on June 15, 2004 at 19:06:32:
Hugh,
Didn't you say you had a '52 or '53 Super A? That would be a good test case for the years in question. The 251069 casting number on the block in question here is a C-113. This is the standard block used in the Farmall C's also. The first C-123 blocks on Super C's have casting number 354898 (original blocks, not talking about later replacements). Also interestingly, they were not putting the C-1xx designators on the blocks yet. I checked '52 and '54 Super C blocks (354898 R1/R2) and they do not say C-123 on them (meaning they possibly could have been sleeved to either 113 or 123's without causing confusion). But I also checked 230/140/240 blocks and they all have the C-123 designation cast in (just above the firing order). I have never taken the time to chase it down on Super A's, but by the parts books they show an engine change at serial number 310,300 which is mid '51 corresponding to when the Super C was introduced. So my wild guess is that all the later Super A's (anything after 310,300) came with the 354898 blocks. If you have/still have a '52 or '53 it would be great to know what block is on yours and whether you still believe it to be the original block.
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Re: Re: Super A cubic-inch displacemen
