Re: Farmall B Problems
Posted by lee on June 16, 2004 at 06:48:20 from (24.24.95.246):
In Reply to: Farmall B Problems posted by David B on June 15, 2004 at 20:51:41:
Sounds like you have the bearing/seal retainer off the tractor? Many times you have to remove the pulley, housing, and large end cap and press the shaft out. If you have the retainer off
you can support it on vise or wood blocks and tap the bearing out with a punch working carefully from side to side and around the diameter it should come out or have a shop press it out.
Post a Followup
: Re: Re: Farmall B Problems
