Removing Drive Dog on M lift-all pump
Posted by nick on June 16, 2004 at 15:40:12 from (152.163.253.103):
I have the pump out. The drive dog has to come off the pump drive shaft but the entire shaft just spins. It is threaded on to the shaft; right? How can I hold the shaft from spinning? Does the entire cover plate come off with the shaft, seal, & drive dog??
Post a Followup
: Re: Removing Drive Dog on M lift-all pump
